brakes need to warm up
RiyadYar
384
NY
so when i got my 89 supra i knew i bought it with brake problems. i put in wagner thermo qiet brake pads all around that were installed last month and have been worn in. i have earls stainless steel brake lines all around. i changed the booster and the master cylinder. also the old fluid has been completely flushed with new castrol synthetic brake fluid and system has been completly bled. now heres the problem last night it was braking perfect and this morning i got up ready to test them some more and i would smash the pedal to the floor but had very little brake. 5 minutes later the brakes warmed up and everything was working extrodinary. what could be the problem ?
figgie
Twin Cities, Minnesot-ah
triple check the brake fliuid level. It might have gotten empty and ingested some air. It sounds like you do have air still left in the system.
One more question though.
Why did you not stick with regular DOT 3 brake fluid? Going higher is not always a good thing!
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
how did the old brake lines look? (make sure they arent leaking, i had a big problem in the back when i had mine)
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Really? Now that you mention this I do vaguely recall something...
I got Valvoline synthetic Dot 3 & 4, should I dump all of it and get regular Dot 3?
RiyadYar
384
NY
the brakefluid is still at max and the old brake lines looked fine. i replaced them with stainless ones
figgie
Is it working for you? Yes? (Not broke don't fix it). If it is not. Then replace.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
I'm finishing a rebuild and partial restoration, i replaced all my hoses, my system was completely dry, the car still has no engine in it so I haven't used the brakes, If it's better to replace it though, I might go ahead and do so, or I'll just wait until I have to replace my pads...
RiyadYar
384
NY
no i beilieve they were the same size..they were earls brake lines from horsepowerfreaks for the 89-92 supra . so i dont think theyd make them bigger
