Brakes locked up on last drift run ??
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
Hey guys,
So I had my brakes lock up tonight on my last run at a Infinion Raceway here in northarn California .
Every one said its my brakle booster and that its bad, So i waited till they where cooled off and drove home
My question is
Is my brake booster bad or the caliper sticking because of pitting corrosion in the piston at the seal rub area.
Warlock1
67
Surprise, AZ
Could be bad brake lines as well. I have had the left front wheel lock up on two of my three Supras. It turned out both times as the rubber stock lines deteriorated to the point of collapsing internally and holding pressure on the caliper. A quick switch to SS and all is good.
radiod
1,342
Abbotsford, BC
I had the exact same thing happen to me only I went through with replacing the calipers before the lines and it ended up being the lines.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
I had that issue(brakes locking up) when I mixed up a bottle of brake fluid with a bottle of power steering fluid... everything rubber was shot....
Sent from my C771
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Sent from my C771
hope you don't have ABS...
Warlock1
67
Surprise, AZ
When you change the lines, empty the reservoir and clean it out to remove as much of the old fluid as possible and then flush the system entirely. If it looked anything like mine there was brown stuff where nice clean fluid was supposed to be. While your doing this and you have brake fluid in hand, you might as well do the clutch system as well.
