Brake Lights Stay On!
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,081
Anaheim/West Covina, CA
before i washed my car today..i noticed that my brake lights were on...car is off nothing should be on...i unplug the lamp failure box and it goes out...my signals work with it unplugged..but my brake lights dont...either i drive with my brake lights on or off....it doesent turn on when i brake cause its already on.....can anyone help?
jetjock
creepy-ass cracka
9,439
They don't turn on when you brake because they're already on? lol...
Checking the brake light switch would be a good place to start. Btw, your brake lights should be operable with the car off. It's illegal in California (and I believe all of the US) to have it any other way.
A-to-the-J
Feb 19, 2006
1,081
i think i confused you....the brake lights stay on when its plugged into the lamp failure box..when i unplug it...it turns off and the brake lights dont work...when i step on the brake....nothing happenes cause the lights are already on...i think there's a short or something...i cant find it...
Maroon88
I collect BHG's
May 3, 2005
50
Cincinnati, OH
As Jetjock said, check the brake light switch. It is under the dash attached to your brake pedal. When you press the pedal it closes the switch lighting the lights. After that check the relay for the brake lights.
shaeff
Kurt is FTMFW x2!!!!
11
Around
key words here: "before i washed my car"
you have a short in the "lamp failure" box in the access panel below the driver's side tail light. disconnect it, pull it out, pop it apart, clean/dry it out, re-solder any corroded connections, and pop it back in.
you should be good to go.
also, find where the leak is that's letting water in. ;)
-shaeff
A-to-the-J
Feb 19, 2006
1,081
-shaeff
doin it tomorrow...and i think the leak is from the taillight seal
