BOV questin
Ymh
120
Oklahoma
i have read on here that i can use any port off the intake manifold, but i also read that different ports off the intake pulls vacuum at different times. Am wondering whats the best line to T into for the bov?
man i missed spelled question
Ymh
120
Oklahoma
gaboonviper85;1096336 said:
needs to be infront of the throttle body.....the closer the better...
like one of the two lines right on top next to the throttle body?
Wait, what? I thought vacuum sources for blow off valves had to be after the throttle body, on the intake manifold. I'd tee into the one on the back of the intake manifold, the one that goes to the heater valve, assuming you do hook it up to a source after the throttle body.
The stock vacuum line is a large line that's on the front of the intake manifold (uses pipes and stuff to go under and then up through the lower intake manifold then across in front the 3000 pipe).
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
I have mine hooked up like stock to the big ol' tee thingy from the side of the intake manifold (like stock) and i havent had any problems yet... mines a turbo xs, and i used the largest hose i could... like... 6mm? it was a decent sized hose though.
