Boost creep problems
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Setup: 1.5JZ 264/272 cams, ITS 67mm, p-trim, .68ar, ebay 40mm HKS knockoff, drewgo manifold, 3" DP to 3.75" exhaust
Is this wastegate big enough to control this turbo? The wastegate seems to hold untill about 5500rpm then it creeps past 20 psi and I let off.
becauseican
Vancouver
www.bicperformance.com
The Drewgo manifold is the problem, they are known to creep with 67 or larger turbo's. I would honestly go with another manifold, I just went though all this recently on a 2jz, DBB T67. With a lot of work and fabrication you can get it to hold, but I would just buy another style manifold for the $200-300 that they cost. The Drewgo manis are fine on the 1jz but the 2jz just has too much exhaust flow to keep the boost down.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
hvyman;1520928 said:
you sure the problem is not the KNOCK OFF waste gate?
Are you correcting my grammar? I'm sorry my lack of spacing on one word can't get my point across to your superior grammatical brains. Or are you saying that the wastegate being a knock off is not going to work? Because I've had 2 setups with knockoff wastegates that worked fine..
GrimJack;1521013 said:
Any ideas how much power you're pushing through it?
I've got the 44mm TIAL on a rather similar setup, and it's working ok...
I'm not sure what you mean by power, like amount of air to the wastegate?
That's what me and a buddy were discussing yesterday. Since it only has the wastegate routing from runners 5 & 6 it's not very efficient. Guess I'll just sell the Drewgo and find something with dual wastegate runner provisions.
Thanks for the insight.
Nghty89
Zombie Chicks Are Hot
Mar 26, 2008
978
7 Cities, VA
I believe he was saying that becuase it is a knock off, it may be the issue. Just because previous experience has worked, does not mean it trumps the logic that knock offs can be junk. : p
Too much air bypassing the wastegate.
Sounds like you're on the right track! : p
My replies in bold.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
which manifold would you recommend? I see a few of the ebay ones I could easily get re braced or fitted to my car and wastegate and such? I am just looking for one that will not leave me with boost creep.
tissimo
Stock is boring :(
Melbourne, FL
Full race.
What spring do you have in the wastegate?
