Boost control problem
Joni
21
Konnevesi, Finland
Hi, I have -91 jza70R and I´m installing apex avc-d boost controller.
I need to find speed sensor wire, but I don´t have it in my ecu harness. :confused:
I use this diagram and there´s no wire in pin number T-8:
http://media.photobucket.com/image/jza70 ecu pinout/BigTSetter/MKIV ECU/1jzecu_diagram.jpg
But, I heard that speed limit can be turned of by cutting pink wire from ecu. I do have pink wire whit 2 silver spot on it, but it´s in pinout number T-19.
Can I use this wire for boost controller`s speed signal? (I have mine´s ecu, so I don´t have speed limiter..)
(Sorry about my poor english..)
Sorry don't know never ran a stock ECU in the car, it's easy enough to find/verify.
Jack the car up put it on stands idle it in 4th/5th connect a multimeter to ground on continuity then find any pink/grey flecks wires and probe it, you should see a bunch of on/offs, while it's connected increase the rpm a little it should increase in frequency then push the clutch and tap the brakes it should stop.
Just keep in mind what I said about it being an ugly signal, the ABS sensor has a much better output.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Pink is what it should be. It should be on your Gray connector ( M1 ) it is located on that plug right next to a yellow/Green which is your water temp sensor, on the other side of the pink wire, there is a open spot.
Joni
21
Konnevesi, Finland
It's ttR so i don't have ABS..
M1? is that ECU connector?
