blower motor dont blow
onejz
BOOOM BOOOM BANGGG
Apr 16, 2006
163
vancouver
Well I have read other posts and followed what they did. Nothing worked my blower is fine but it wont turn on. I can here something moving from low - med - high . Took out the glove box see that the flaps are moving fine but still no motor moving. Any one help?
kotu100
1,899
Easton, Ma
What about the resistors? Little black box under the blower. Take the screw out and remove it gently. Bet those wires are broken in there.
onejz
BOOOM BOOOM BANGGG
Apr 16, 2006
163
vancouver
well i tried a 7m blower in it and it did not work either I do not think a right hand drive 1j would be much diff then a 7m blower
f00g00
586
Kuwait
I agree, but normally the blower will work on high if its bad.
onejz
BOOOM BOOOM BANGGG
Apr 16, 2006
163
vancouver
I took the blower out tested it all is good coils are good also not sure if. Iam missing something somehwere if I knew where the proper relay was maybe it is that but can not find nothing for a righthand drive
bioskyline
1,236
powell river bc
there is a relay for the blower in the kick panel fuse panel i think. its on the passenger side for the MA70s, so maybe it will be on the passenger side of your car
onejz
BOOOM BOOOM BANGGG
Apr 16, 2006
163
vancouver
Ok fixed. All that was needed was a wire replaced behind with the relays were. I guess it had some water leaked in. Thanks for all the help.
