I just picked up another supra with an unassembled machined motor I was hoping to use.
Unfortunately it has a crack in the #2 piston water jacket where the casting divider meets the piston wall, the side with 2 water jacket holes. This is on the deck.
:1zhelp:
Is this block trash? Would it threaten the integrity of the head gasket on a NA motor or cause piston ring problems (like flex in the combustion chamber)?
Can't believe his machine shop decked & cleaned this block and took his money knowing the block has a water jacket crack. They are either dishonest or don't care.
:1zhelp:
