blinker
MKIII TURBO60-1
156
Ocala,Fl
my right rear blinker light does not work, i replaced bulb and cleaned up housing, thinking about replacing the whole plastic holder, any other ideas on how to fix or just replace, all other lights work
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
That means its not getting any power, trace the wires and make sure they aren't burned out anywhere, best case scenario, there's a lose connection that can be pushed together..
Or maybe even the hazard switch, might be a long shot but I've seen stranger things..
MKIII TURBO60-1
156
Ocala,Fl
all other lights work fine, i dont think its the hazard switch cuz all the other light flash like they are suppose to, i think its the metal housing that actully holds the bulb in place
RazoE
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
check it out and have a look-see...
the hazard switch does afect the signals, if it's unplugged, you'll lose your signals (which is why it's worth taking a look at)..
I personally doubt it, but you never know..
