black smoke & smells like..
catback
bitterville
gas heavy.
dead cyl.?
i'll be checking everything tonight.
any ideas hints where to look
ill be checking all ignition parts , hopefully its not a stuck valve
shaeff
Kurt is FTMFW x2!!!!
11
Around
more than likely a bad plug wire, or plug itself.
-shaeff
catback
bitterville
it runs fine , smooth idle, just smokes like crazy :nono:
if it was a plug or wire or even stuck valve wouldnt it run alittle funny?
i'm doing a compression test tonight (fingers crossed).. hopefully good news.
would a bad injector cause something like this?
JDM engine has 700km since it was freshenned up:
arp hardware, toyota complete gasket kit
60-1 ct-26
walbro 255/filter
stock inj :icon_conf
stock afm
ic hardpipes
NGK wires/plugs 'NEW'
3" turbo back
boost hasnt been raised from stock yet!
help any ideas :1zhelp: :1zhelp: :1zhelp: :1zhelp:
mkiiSupraMan18
Needs a new username...
United States
my old mkIII did this, it was a cracked lower boost hose.... shot black crapp everywhere, but I see you already have a hardpipe kit installed...
temp switch hooked up..... working?
Codes?
catback
bitterville
OK did a compression test twice and
#1 147
#2 149
#3 147
#4 148
#5 148
#6 148
2nd time
#1 152
#2 156
#3 151
#4 151
#5 150
#6 151
there was alot of oil on the #2 plug and smelled like gas
engine code 51
thats the TPS code right?
could this be causing it?
will the JDM TPS work on my 87?
catback
bitterville
i'll check all the piping tomorrow @ work
hopefully that's it :icon_bigg
thanks guys
wohoo 50 posts :biglaugh: :drink1:
catback
bitterville
checked the ic pipes and they're fine /as far as i can tell
started up the car and it ran like shit. checked codes again and now i get :aigo: :aigo:
14 ignition signal-----What do i check?
31 afm signal------time for lex afm
34 turbo pressure signal-----apexi avc-r just installed? could this cause it
now the car wont idle(sputters and dies, still smokes)
