BigZavs T56 swap/Finishing my 1.5JZ project
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
started pulling everything off the car today, trans is ready to come off, just didnt have time today to pull it off.
started working on the pump hanger to run the lines. need one more bulkhead fitting tho.
put some VHT high temp paint on the exhaust, make it look a lil better than it did on the car
also, couldnt find a pilot bearing with the two sizes, ID for a T56, OD for a JZ crank. ended up with a brass bushing for the LT1, going to take it to my machine shop and have it turned down to match the JZ's crank.
also picked up a energy suspension poly mount for the trans
heres a comparison of the driveshafts, hoping it comes out without too much work, T56 looks a little longer, so hopefully it comes out.
heading over to my friends house to pick up the centerforce clutch. thats it for today tho
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
thanks guys
can only hope it is Jay
heres the updates.
R154 and OS Giken off
after just kind of holding the T56 up in location, shifter wise, it looks like ill need to notch the back of the shifter hole 3/4"-1" to fit the hurst shifter.
fuel pump hanger is done, just need to redo the power/ground connections and its good to go.
also took out all of the HVAC system, not gonna need it by the time the cars running.
during
after
pilot bushing is at the machinist as of this morning, alot with stock to make the spacers for my rear brake kit.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
next up we have the parts that came in today
Bronze shifter cup (equivalent of the marlin crawler seat)
Centerforce clutch
Quartermaster slave cylinder
PT76GTS (needs a rebuild and a new wheel, but got it for a friggin steal)
PT76 next to the T88
the turbo will be going to Majestic Turbo in Irving on monday to get rebuilt.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
kamikazemkiii;1508392 said:
Looks good, what are you shooting for?
keep up the work
im shooting for driving, i could make 150whp at 45psi and not really car (well i would care, but you get what i mean), i just wanna drive it
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
Supraholics;1508783 said:
Why such a big turbo if you just want to drive it around? Are you looking for more than 500whp?
when i said drive it around, i meant just to get it on the road, its been off the road now since last august. in no way is the car a daily driver, ive got a grand am for that
The car is setup for E85, and so is the tune.
in a couple months, the Trans will be getting built up to Viper specs, and a twin disk will be going in.
then the boost will be going up to 28-30psi
Supraholics
.928 RWHP & Climing!
Apr 1, 2006
1,577
PA
www.supraholics.com
From reading your posts I deduced that much. It wouldn't make much sense to DD it. You still didn't answer my question. Not that you have to answer, just curious why you would want such a big turbo for a car you're building to drive around. Your car wont be much fun except for doing highway pulls...
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
thats where it will be driven around.
two reasons, number one is i had the same gearing in my firehawk, T56 + 3.73's is a shit ton of fun on the highway
two, the local mkivs are all big turbo cars, 74's, 76's, 80's, some billet turbo's, gotta keep up with em
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
progress so far.............none other than the turbo is being rebuilt at majestic.
got up to see this in the morning
keep in mind, this is north texas, my mom has lived here her entire life, and hasnt seen this much snow in 30 years
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
suprahero;1512242 said:
How about less snow and more progress............:biglaugh:
tell that to our weather, for all i know itll be 100 degrees tomorrow.
shit, power just flashed, another transformer exploded. i did actually make progress, wiring harness is finished, except for wiring up the UEGO, but thats just one wire into the AEM
