Big 1jz build in Chicago
armyboot
26
canada
87M-GTE;1644561 said:
That T88 equated to being a 42R also doesnt it?
What all was stock on your 1JZ?
Sam
Kinda, both 76mm, but my greddy has a slow journal bearing and larger exhaust ar. A gt4276 will spool a few hundred rpm sooner. I started getting a good amout of boost around 6000rpm. I'm guessing a gt4276 would get good spool up around 5700rpm on a 1j.
On my 1j, my complete engine was stock. head wasn't even lifted. I had only swapped in new valve springs and bc272 cams. added big turbo+fuel system+standalone+big intercooler+4inch exhaust. it was hiyway monster only. forget about city driving. City driving was horrid.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
How did you upgrade your valve springs without taking the head off??
armyboot
26
canada
Put the piston at it's highest position, then leave the car in gear. Pulled out the spark plug and hooked up the air compressor to keep the valves from dropping. Then swap springs and valve seals while in there.
I did drop one valve as I lost air pressure, but it droped on the piston. But since the piston stops it from dropping into the engine, I just pulled it back up. Getting the retainers back in with aftermarket springs is the hard part.
IBoughtASupra
4,455
Queens, NY
This works really well to help put the valve lock back in place.
http://www.amazon.com/Lisle-36200-K...ZJIS/ref=sr_1_9?ie=UTF8&qid=1291245965&sr=8-9
mk3tattoos
1,104
Bremerton, Wa
sorry for not posting the link sooner, have not been on this thread in awhile:) here it is.....
[video=youtube;kivHuHe0PgQ]http://www.youtube.com/watch?v=kivHuHe0PgQ[/video]
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
No, I have been extremely busy at work, Plus this suckie weather does not motivate me at all.... I did mate the V160 to the long block, Plus kinda clean the harness a lil bit... hopefuly this weekend I do more,,, motivation where are you? :(
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Jostar;1657452 said:
this suckie weather
Yep.
Well gathering parts, Waiting on a manifold still.
It'll go in the car once the weather is more like 40s and up lol
This 20 degree BS is painful to work with especially in an unheated garage!
Sam
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
87M-GTE;1657726 said:
Yep.
Sam
which is why I bought a torpedo heater at Menards today for about 100 bucks ;)
Jostar
May 21, 2007
746
Chicago
Maybe tomorrow.. I had to get a 2jz starter as the 1jz starter does not fit the getrag bellhousing..
