I'm not sure yet cuz the engine has been rebuilt 10,000 miles ago.
The symptoms
Hard to start, white smoke and I have to add coolant every 3 days but just a bit. I'm going to get the test from napa and see what it says.
What do you think of this? or it's just BS
HOW AND WHY DOES STEEL SEAL™ WORK?
Steel Seal™, the only product of its kind, permanently seals blown head gaskets, warped heads and cracked engine blocks and heads.
Scott Laboratory has performed a thorough evaluation of both Steel Seal™ and its competitors and found Steel Seal™ to be superior to all products tested. Steel Seal™ has been used successfully in over 20,000 vehicles.
Steel Seal™ creates a permanent seal that will withstand high temperatures and high pressure. The product can be used in both gasoline and diesel engines.
Steel Seal™ combines with an antifreeze/water mixture and is poured into the radiator of a cold engine. Once the engine is started and reaches operating temperature, Steel Seal™ is distributed through the engine. The product is drawn into the damaged area and seals the crack with a thermo-chemical bonding action process.
Comparable products rely on fillers to do the repair work. But as pressures rise and fall, as in ignition and shut off, the particles lodged in cracks and leaks become loosened. Since their products’ true strength is defined solely through consistent engine pressure, the consumer inevitably finds him/herself in the same original predicament that led them to an inferior quick fix.
Steel Seal™ is a unique blend of several chemicals. Steel Seal™ is a clear formula that contains no fibrous materials or particles that could clog engine coolant passages. We don’t rely on floating particles to do our job. Steel Seal™ relies on science and chemistry for its strength.
Regardless of the value of an automobile, you now have a practical solution. At a fraction of the cost and time of major engine repair, Steel Seal™ empowers the individual professional technician to take advantage of a scientific breakthrough – one that will revolutionize engine repair technology.
With strict adherence to the manufacturer's directions and proper diagnosis, you will enjoy virtually effortless engine repair that will free you up to maximize your shop day.
The symptoms
