Well, I have blown two radiator hoses off now. One(top) was the original hose. I have no clue why I reused it. It swole to about 2.5 inch diamater and began to leak around the stock spring clamp on the thermostat housing. OK, so I replaced that hose three days ago, and used worm gear clamps on it. Its fine.
The bottom hose popped off today. It slid right off of the koyo radiator. It was a new hose, but using the original spring clamp. The hose was unhurt. This happened after I cut the car off. I was walking to the house, and got on the porch when I heard it pop and saw steam go everywhere.
I did a compression and leakdown, and both reveal everything to be in good working order. I am not losing water normally, and there is no water in the oil or combustion chambers. The coolant resivoir does not get low, and I have a 16 psi TRD radiator cap.
The head gasket is a cometic 2.0 mm 590 miles. ARP head studs where used with ARP moly lube, and where retorqued at 500 miles. Torque is 85 ft/lbs. When the engine was put together the block and head where both surfaced to the correct finish. Both head a block are true and straight.
Is this just a freak thing, or should I be worried.
