Best gap of the spark plugs and timing for a 75 HP nos?
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
What will be the right gab and timing if I use a 75HP NOS shoot? :1zhelp:
My spect:
T4, hot side .68, cool side .70
Water injcetion set on: 10 psi
Max boost: 17 Psi
Walbro FP
RC 550
FPR with vaccum set at: 26psi
Hard IC of 2.5"
mkIIIman089
Ohio
I wouldn't close the gap unless you start having problems, personally.
1 heat range colder is a good idea though.
Colin: It's just a suggestion to make sure it's on the safe side last thing you want is spark blowout.
Ideally the biggest gap that will still fire is the best but not knowing what condition or state of modification the car is in I err on the side of caution.
mkIIIman089
Ohio
I'll put it this way, since I do agree with you.
I wouldn't, he should. ;)
Just like I don't ever recommend an electric fan to anyone, or numerous other things I do which could lead to disaster if someone else tried it.
suprarich
Guest
Nov 9, 2005
2,187
ohio
I agree, 1 range colder, .025 to .027 gap. Run nothing but the best gas you can find. Do not run more than a 75 wet shot with pump gas.
