BC264 cams in 7MGTE - overlap?
BLACKCAT
185
BHG
Installed a pair of BC 264 cams in a 7MGTE recently.
According to the cam card they have 36 degrees of overlap.
It certainly does not like that much & I had to reduce it to 32 in order to get a decent idle & prevent occasional stalling.
I can easily reduce it further but am concerned at bumping up dynamic pressure too much.
Is that still too much overlap for the 7MGTE & if anyone else has installed the same cams what adjustment to cam timing was made?
PS: Lost 10-15 psi static compression from the original Toyota cams but goes MUCH better now.
MRSUPRA
838
Maryland
My BC264 cams never idled good at 0,0 cam gear settings on the stock ECU. With the AEM, I have the idle set to 950rpms. I have the cam gears clocked for the most power now but I cannot remember what the settings are off of the top of my head.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Heh, 0,0* on these things idle like a bag of rocks with the stock ECU. I've been working on a car that has these cams.
He needs to get some adjustable cam gears, at the minimum. There's only like 10in/hg of vacuum at idle, too. Not so good.
BLACKCAT
185
BHG
Running a Microtech MTX-8 standalone.
Idles at around 750 rpm (15-16) in neutral & 680 in Drive (14) when warm.
Adjustable cam gears certainly come in handy with these cams.
Needs to be warmed up a bit when dead cold not like my N/A which could be driven immediately with these cams.
Not having the cold start injector wired up does not help things.
BLACKCAT
185
BHG
Forgot to mention that I did not degree them just installed straight up as I finished working on them at midnight & was stuffed.
IJ is right about taking the time to degree them properly.
Will probably do that this weekend just to see how much they are out & what the difference in idle quality will be.
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
Issues like these are what makes me hesistant to purchase the BC cams. I have adjustable cam gears, I just haven't read enough positive feedback to warrant spending the money and dealing with the headaches....
-Mo
MRSUPRA
838
Maryland
/\I don't blame you. My first set of BC264's would not allow the engine to idle at all at 0,0 setting, not even close. I sent them back to BC to get checked out and they said they were fine. So I told them to give me a different set and they did and my car idled again. It was a major hassle with the hours and hours of me troubleshooting my new motor. Anyway, I'm making very good power now with the BC264's.
BLACKCAT
185
BHG
Time for an update.
Degreed the cams & yes they were both out a bit.
According to the cam card info, ie @ 0.050" lift I opens at 0 (TDC) & E at 48 BBDC, my ideal setting should be I +4 1/2 & E + 3 1/2.
Well at those settings it wont idle cleanly as the vaccum is crap & stalls pretty easy, even in neutral.
After a lot of stuffing around trying different combinations I ended up setting my cam timing at I +2 & E +3.
Goes good now & has no trouble pulling redline in second, only 5psi boost, wonder how the valve springs & bottom end is coping?:aigo:
Now I need to get it dyno tuned to see the difference these cams have made.
For anyone trying to tune these cams this is what I did:
Ended up setting the exhaust at +3 adjusted timing to 10 degrees & dialing the intake to -1.
Progressively advanced the intake cam by one degree increments & at the same time increased the idle speed (turning clockwise) with the adjustment screw. If you dont alter the screw setting it will idle too low & stall every time.
Any higher than 3 & I could not get a decent idle, too much overlap starting to creep in I suppose.
You must tune it with the engine at operating temperature, take it for a drive & then make minor adjustment to idle speed if required.
