Bad Rear End Chatter?
Emeraldage
322
Ohio
I've had this issue for awhile I bought a 3.73 LSD from another member here, he had to ship it dry. I originally put Castrol 80-90 (http://www.oreillyauto.com/site/c/d....oap?ck=Search_N2367_-1_-1&pt=N2367&ppt=C1985) in it. As I drove it the first time when turning the inner wheel always was locked up. So after a bottle in a half of motorcraft friction mod it's mostly gone. But in parking lots tight turns or loose gravel the inner wheel will still skipp about or leave tire marks on tar. I added another bottle (After draining some) and it got better but still definitely has this issue. The oil that came out was black and goopy thick.
Should I just drain and add lots more modifier maybe try redline's? Was the original oil bad and I should replace it with something else like 75W-140 since it already has the modifier applied? Or is this rear end just need servicing and clutches replaced?
Bogwon
452
Bremerton, WA
I used redline 75w90 in my 3.73 with about 1/3rd of the motorcraft friction mod and my chirping is now only when the car is cold and I take a tight (full lock) corner.
If after a whole bottle of friction mod and then some and you're still having issues, that sounds to me like a mechanical problem and not an oil or additive problem.
I also had mine rebuild with a weir performance kit, new seals and bearings for around $300 (not including parts). Good luck!
Oct 11, 2005
3,819
21
Thousand Oaks, CA
Try some synthetic Mobil 1 gear lube. My experience with it was that the clutches did not lock up enough with it, but yours seems extra tight so it may work better. I am a bit confused though, how did black goo come out if it was shipped dry?
IndigoMKII
2,181
Madison, Virginia
Probably got shipped dry and it was just installed, not cleaned out and looked over before installation.
Emeraldage
322
Ohio
I've read it's a very tight diff because it's actually air tight which contributes to it apparently, kind of impressive opening that cap after weeks and hearing air pressure blow out. I've also read that the ford gear oil and additive do magical things for our diffs. I don't understand how the clutches being old and worn out would grip more to me I think it would mean they slip more but I don't have really any experience with clutch LSDs. My original 4.30 one was leaking and I added same castrol stuff and it was fine. Granted I didn't replace all of it I don't know what was really in it. Would like more opinions I'm thinking about trying the mobile stuff. I remember someone mentioning that in another post about this about it being too slippery.
Emeraldage
322
Ohio
Was shipped dry. I thought it would just take time to soak as when I went to the ford dealer they say they soak their LSDs for about a month before they install them. But no I did not take it apart or anything I knew nothing about them.
I was looking at this forum post. (http://www.supramania.com/forums/showthread.php?157104-LSD-fluid-recommendations/page2) And they said Royal Purple is the brand that is too slick.
IndigoMKII
2,181
Madison, Virginia
There's your problem, you went to a ford dealer asking for help to repair a vehicle.
I'd get the diff pulled and find out why an 'worn out diff' it grabbing harder than they did from the factory.
Emeraldage
322
Ohio
Naw I got it from someone on here. I just asked them at ford when I was getting the modifier about it. Unless the previous guy did something to them, I mean when I add modifier it still makes it better. Just a pia to work on them and I don't have the money to rebuild or get a new clutch pack at the moment anyways.
Oh just remembered something. Can too much oil be a problem? I know when my friends installed it he just filled it up till it was spilling out which was just a bit over 2 quarts.. Rather than the 1.3 the TSRM calls for.
Bogwon
452
Bremerton, WA
First of all, the LSD in our cars are not air tight. There is a small valve at the very top of the housing that allows for expansion of the oil once operating temperature is reached and pressure relief, if that valve was blocked with road grime then you pop a seal.
Second, if you want to read about LSD oils do a quick search in the "oil/lubicant" section, there are a ton of topics on which oils perform well. I will say that the motorcraft and redline oils are among the favorites but you'll have to add the friction mod as stated in prior posts. Also you don't want the synthetic version as it's too slippery for the clutch packs.
Lastly speaking of clutch packs, check out the weir performance website and read about their findings on the rebuilds they have done over the years. Spence said he hasn't seen any stock LSDs from our supras with worn out clutch packs because the pinion preload spring was too weak and Toyota used a crush sleeve to preload the pinion gear. This made it so we don't wear out the clutch packs and in most cases the car turns into a "one tire fire" after a couple hundred thousand miles or so...
Emeraldage
322
Ohio
So in your opinion what do you reccomend me doing? Does too much oil make it worse? Should I just drain more oil and add more friction mod? Or start over with a quart of oil and a bottle of friction mod? That oil from my ford dealer is 20$ a quart.
Bogwon
452
Bremerton, WA
I would take it out and have it looked at by a shop but you could try some different gear oil if you think it's still an oil issue. If you want to try to start over, you might try the redline LSD oil and you won't have to mess with the modifier. It's really up to you but if it were my car, I'd pull the diff and looked at by a reputable shop at the very least but I tend to over do things.
You also might drain it in a clean oil catch and see if you get any sparkles (shavings) in the bottom. If it's good you can reuse the oil you drained.
Too much oil is probably not good. I imagine you are more likely to blow a seal if you're over filled and run it that way.
Emeraldage
322
Ohio
Okay. Maybe I'll just drain mine. Get a quart of redline, and recycle a bit of my old oil back in? It's been about 5 months now and it hasn't leaked any but yeah I'll try to get it back down and closer to the 1.4 quarts the TSRM wants.
Bogwon
452
Bremerton, WA
3p141592654;2028001 said:
The pinion preload issue has nothing to do with the clutch plates and plate wear.
I beg to differ sir.
Quoted straight from the weir performance web site:
"This LSD is known for its lack of performance, this is for the most part caused by sloppy assembly at the factory. We have opened up many of these units and have not seen one yet that was worn out. Unfortunately these LSD units do not have clutch members or pressure rings to apply clamping force to the clutch plates. In order for these LSD units to function properly for performance applications they need to be correctly shimmed and the spring pressure increased."
Oct 11, 2005
3,819
21
Thousand Oaks, CA
There's nothing there that contradicts what I said i.e. pinion preload is a separate issue. The clutch preload is set by the springs and shims selected. The Weir MAX GRIP LSD kit is just a spring that goes inside the stock spring that applies pressure to the outer spider gears and clutches. The pinion preload is set separately and has nothing to do with the clutch plate preload.
In a nutshell you are confusing pinion preload with clutch pack preload.
If you want to learn more read this treatise:
http://www.supramania.com/forums/showthread.php?203766-HOW-TO-Rebuild-the-MK3-Rear-Differential.
