Hey guys. I recently finished my engine rebuild and during one of my drives, my oil pressure gauge suddenly stopped reading (the needle dropped to rest position, not zero). I immediately pulled over and had my Supra towed home.
Note: there was NO CHANGE it how the engine ran, behaved, or sounded. If I had really lost all oil pressure like that, I'm sure it would have rod knocked before I could do anything.
After I got home, I took my oil cap off and lo, there was oil flowing and splashing around like normal. I tested my oil pressure sender by putting the leads of my ohmeter on the signal tip on the pressure sender and a body ground, nothing, no continuity. I made sure the grounds were good by putting one lead on the engine block itself right next to the pressure sender, and behold, perfect continuity.
I also tested my roommates MK3, to see if there was continuity on his 7M between the sender and body, and his had continuity. I concluded that my oil pressure sender was bad.
Does anyone disagree or have ideas?
I posted this thread because I recently received my new OEM pressure sender from Toyota and there was no continuity between the two ends of the sender itself, not sure if that is normal or I got a bad sender...
