I am a little confused about an idle issue with my car. It idles fine under all conditions except when I roll down my windows, turn on my blinkers, turn on my headlights, flashers or anything of that nature. When I do any of these things, my car will drop idle noticeably and act as if I have put a high load on the electrical system and the motor drops down in RPMs. When not using any of these, it idles fine at 650 RPMS per TSRM. My timing is fine, (just did it last week), and it seems to act normal except for the conditions I described above.
Anyone have any ideas?
I am stumped. I have two ideas, failing battery not holding a a full charge, or failing alernator that is not putting out enough juice. I am going to go to Autozone tomorrow to test both and go from there.
