Autometer cluster idea
TheNewRed
572
WA
Dmanit, im not really concerned about TEMS, but thats goning to suck if it causes me to lose ABS. But your right they all have their own controller so, and i dont want this thing throwing CELs either???
Grimsta
1,081
Santa Rosa, Ca.
Well I can tell you the speedo has nothing to do with ABS. thats what your wheel sensors are for. The speedo output to the ECU has to do with fueling and detecting engine load. Based on vehicle speed, MAF reading, and other inputs it determines air density and engine load to assert a proper amount of fuel. My car on its previous engine with the previous owner had the speed sensor disconnected and when he boosted it leaned out and developed a rod knock and that was on stock boost levels as well
Suprafast0422
107
Maryland
I saw a really sweet custom cluster on a 240 a guy did awhile back, ill try and find it when i get home tonight. If i remember correctly it looked almost factory.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
all that i can remmber is abs is all so trigger from the rear trans sencer and front wheel sencers
ask me how i know
(cough) down shift chrip ,2 way lsd,corner wtf no brakes
don't think the one off the speedo is that importain when it all ready has sorcer from the trans sencer and goes right into the ecu
TheNewRed;1144278 said:
HAHAHA thanks I.J., i promise it wont lok like shit! But anyways no one knows what the signal to the TCCS is used for? Williamb, Keep me posted, i want to see how it turns out.
dbsupra90
toonar
indiucky
i also know the spd signal is used for auto trans shifting. the ect ecu looks at sp1 (speedo signal) and sp2 (rear speed sensor). if the 2 signals do not match it will set a code 61 and will go to a default shift table. also, it is a digital signal, you can see it with an o'scope. i can't confirm if it uses the spd signal for fuel mapping, but the above i do know for sure.
marlin rock crawler makes an adapter for the speedo, and dakota digital sells a signal box with analog/digital outputs.
