Automatic Transmission Fitting Size
jdub
Feb 10, 2006
10,730
Valley of the Sun
What tranny cooler are you installing? -8 lines are a better choice in terms of flow to the cooler (assuming it's got 1/2" NPT inlet/outlets).
-6 lines will work...the ATF circuit is bypass system, so no fluid restriction issues to the tranny.
Apollonius
105
Houston, TX
Damn could of swore i read to use 6an lines... At least there won't be any issues since i already bought the line and fittings
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM-70273&N=700+115&autoview=sku
Thats the cooler i went with
jdub
Feb 10, 2006
10,730
Valley of the Sun
Excellent cooler.
The -6 lines will just restrict flow to the cooler a bit...I have a tendency to go oversize though ;)
Did I see a filter head in the other thread for ATF in your cooler circuit?
What filter?
Apollonius
105
Houston, TX
Yep you did see a filter head for the tranny ;)
Trasko TI-10S
jdub
Feb 10, 2006
10,730
Valley of the Sun
You've been paying attention ;)
Another excellent choice...that filter will go 15K easy on ATF.
jdub
Feb 10, 2006
10,730
Valley of the Sun
The only issue you *may have* is with the block adapter inteferring with the turbo/IC pipes. I have the same one you do and it's fine...a few guys have had to go with a side port block adapter though.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Apollonius;1137616 said:
It interferes .... I can't put a 90 bend on the return port, Going to try a 45 bend to see if that will clear it gotta order it though.
Any tips on tightening it? they might both fit if i can get it to turn parallel with the ground
http://store.summitracing.com/partd...849624+4294906748+4294906674+115&autoview=sku
Would work for sure, but don't want to put a straight 90 bend on it... the whole restriction to flow thing
You could play the loosen NA stud game and spin till it is...that what I did, and the ports are parallel to the ground, Or you could use this:
http://store.summitracing.com/partd...1&part=TRD-1413&N=700+400158+115&autoview=sku
I wouldn't use a hard 90 fitting like that...you are correct, it's as restrictive as 10' of hose. ;)
