automatic tranny help
supr88
turbo addict
May 15, 2007
94
calgary or vancouver
i hope this hasnt been asked 100 times already, i did spend hours reading various threads though.
my setup is a 1jzgte with automatic tranny from a soarer swapped into my ma70. ever since i finished the swap everything has been running really good except for one small thing that bugs me. from what i gather, the tranny is in 'manual shift' mode. that is to say D is neutral, 2 is overdrive, and L is 1,2,3. I notice in L it shifts much more tightly through 1,2,3 but in 2 its mushy through all gears. I figure this has something to do with it being in 'manual mode.'
when i got my tranny and engine for the swap some of the harness had been damaged, the part that goes to the tranny so i repaired it. i suspect i missed something though, but have been unable to extract trouble codes from the ECT. I have tried paper clips and a wire to the E1 and TT terminals. Also tried it between E1 and TE1 and I cant extract CEL codes either now, which did work before, leads be to believe the E1 terminal isnt grounded or something like that. Can i take a wire in the TT terminal, and just ground it out to something with an aligator clip? The OD light isnt burnt out either, i checked that.
Is there anything to gain by getting my ECT working properly? It would be nice to be able to select any gear I want with the shift lever and shut OD off with the button. Seems to shift much more crisp in L, does it get better than this? Also I seem to have a dead spot when im cruising going 70 and step on it, it just feels mushy and wont downshift, not helpful if im trying to beat some punk from a roll. If I go from a stand still its tight and accelerates like a bullet.
I know, just get rid of it and get a 5spd, but that is not economically feasable right now, unless you want to make a donation. Its on the list of things to do, but wont happen for at least a year.
thanks for the help
mike
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
I'm watching this thread, as I'm almost having the same problem as you after my GE to GTE swap.
With my car, if I put it in drive (D), it takes off in 2nd, shifts to 3rd; then never shifts into overdrive after that. I can shift it through the gears manually, 1->2->D; but it will never shift into overdrive once I reach D.
Also, I can't pull any codes off my tranny's computer. I can jump the terminals in the diagnostic box, but my O/D light doesn't flash; meaning that the tranny's computer isn't going into diagnostic mode. (Yes, the O/D light works fine).
