i know that there's the Auto Up for the driver side door mod, but is there a way to make the Passenger Window Switch (on driver side door) auto up and down as well?
It 'might' work. The plug may be different. Pull them out and check if you can do it. I found out one thing, you can NOT unplug the passenger side wiring (on passenger door) because then neither window works. All the switches had to be plugged in to make either window work.JD7Monster said:Im sure if you got an extra driver side switch, and used the Driver switch in the passenger side switch holder thing, you could get it to work the same.
Good luck? if that made sense..
Pull yours out and see if the plugs are the same. I found out on mine that you can't unplug the passenger door switch, cause then none of the switches work. They all have to be plugged in.JD7Monster said:Im sure if you got an extra driver side switch, and used the Driver switch in the passenger side switch holder thing, you could get it to work the same.
