Auto Trans Control...?
AcIdBuRn02ZTS
227
Indiana
Quick question...
Is the atx in the supra controled by the ecu or by a seperate control module?
If its in the ece... can you use an mt ecu and use something such as Supra Stick to control the atx?
Reason for asking... I'm building an atx turbo car but have a manual ecu/harness... so wanted to know what I could do.
Thanks
-AcId-
8,898
The ATX is a brand name for Ford front wheel drive transaxle....
The transmission is controlled by its own ECU, which also recieves input from the engine ECU.
AcIdBuRn02ZTS;1493213 said:
Quick question...
Thanks
-AcId-
Yes.
If you have the $ get a PCS controller.
