Auto Trans Code 62 and 64
iwannadie
981
gilbert, az
Auto trans codes
62 - severed no. 1 solenoid or short circuit
64 - severed lock up solenoid or short circuit
Has anyone ran into either of these? After reading through the tsrm it really seems to be a wire issue not a solenoid failure. Since both share the same wire harness even.
Ive tried checking the ect ecu according to the tsrm. Says to use a multi meter and check the resistance of 3 pins on the harness side. Well im getting no reading at all, so either thats the problem or Im not using testing correctly lol.
So any ideas, Im totally lost when it comes to this sort of wiring issue...
