Auto Tranny Question Noise Related
JDMMA70
2,550
Houston
I recently swapped out transmissions in my car, to a cleaner used 1jz auto. If shifts fine, smooth, still need to adjust the kickdown cable but, there are no problems going into gear, or shifting. However theres a buzzing sound, which i have a hunch is electrical because lets say if i roll down my windows or up, the buzzing sound goes away, but comes back once the windows are up. You can only hear it faintly in Park, and Neutral. In Reverse and Drive, its audible, but not overly obnoxiously loud. While the transmission was apart, the filter was replaced, and magnets were cleaned. Im assuming this is the solenoid, my dad and i checked them multi meter, before sealing things up, and they were in spec as per TSRM. Should i not worry about it, if everything is working fine. Im running Toyota T-IV ATF in it.
Thanks
~JDMMA70
8,900
What about other electrical loads?
I was thinking about your problem, and can't see how the integration relay and trans are connected. Unplug the range selector so it is operating mechanically only and see if you get the noise. Do you have the full swap harness from your 1JZ donor? Did you mix anything?
JDMMA70
2,550
Houston
All the plugs from the 1JZ trans plugged right into the 7M harness. My alternator is on its way out if that affects anything, however i do know the buzzing is coming from the trans area.
