Auto to manual conversion
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
I'm converting my 89 mk3 from auto to manual here's my parts list.
clutch master cylinder
slave cylinder
clutch line
clutch pedal
manual brake pedal
I have the trany and drive line, is there anything else I need to do for this conversion?
supradavenz
LOL HIES!
Apr 1, 2006
159
AUCKLAND, New Zealand
spigot bearing that goes into your crank.. its just a standard ballbearing that keeps the gearbox shaft from moving around to much. for a 7m the bearing number is 6201-2rsj i used this for a W58 i dont think theres any difference if its a R154 tho but dont hold me to that. plus theyre only a couple bucks.
djordan97
199
Kennewick WA
there is also wiring to do and then you have your shifter shift boot rubber shift boots as well and your interior shift boot there is also a bunch of washers spacers and springs for the clutch and throwout bearing. also the drivers side I believe transmtition to engine brace is different than the auto one as well. drive line is different as well. that's all I can think of off the top of my head.
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
the wiring part, whats diffrent that i should know about before doing the conversion? the 7M and manual trany i'm getting is comming with it's own harness. when i drop the engine and trany, the wiring is pre-done on the engine and trany to begin with so i should be able to just plug the ECU right up for that right? is there anything special past that point with the wiring that i should know?
djordan97
199
Kennewick WA
if you have the wiring harnesses then there shouldn't be any I'm not positive on that aspect cause I used the auto wiring harness and the auto ecu and just wired in a clutch switch and the revers lights and abs and all that so I'm not sure about the wiring then.
