Auto A340E ?
Spade
7M or DIE Trying
Nov 26, 2007
Asheville
I was wondering how much upgradeable the A340E auto trans is? Also how much power can the stock trans hold? If it is upgradble where can you git the parts?:1zhelp:
Ma70.Ent
1,871
NJ
I typed in "upgraded A340e" in the search window and got good results. Try it sometime..
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Well its been said by others that the stock auto tranny holds around 300hp.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
IJ. said:
Beat the Snot out of my built 340 at 550rwhp no probs :)
+1 - I'm running a built a340le (jdm-soarer version, same thing), lotsa hp...no problems.
Word to the wise - what I am refering to (as well as IJ, I'm sure) is a fresh, fully and correctly built, healthy, auto trans. I've got kevlar clutches, shimmed accumulators w/ heavier than stock springs, high performance pump etc.
If you are putting big hp into a high miles, worn trans w/ bad seals etc., expect problems as you would in any transmission in that condition that you are putting more strain on w/ additional hp.
The a340 gets a bad rap in my opinion. It's a very sturdy transmission.
I would only consider swapping in something else (namley a th400) if I decided I wanted to go with a trans-brake for drag racing, the fact that I even consider the need for one should give you some idea of how badly I abuse my a340. Unfortunately, a trans-brake cannot be done with the a340. Other than that it's all good.
Spade
7M or DIE Trying
Nov 26, 2007
Asheville
Why can you not put a Trans Brake in the a340e trans?
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
^It just doesn't work like that!
People really do underestimate an A340E.
Given it hasn't been abused by previous owners, they are pretty sturdy transmissions...However, anytime you start throwing power 100+rwhp more than the car came stock with, you better believe you're cutting down its life expectancy.
At the moment, I'm running a stock, HEALTHY A340E, First thing I did when I put it back in? B&M Tranny Cooler. I was cranking out over 300rw for about a year, daily driven, no problems.
HEAT is the big killer with transmissions...Remember that.
With that said, You can beef up a 340 to do pretty much whatever you intended to do. ;)
-Jeff
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
HEAT is the big killer with transmissions...Remember that. Jeff
Yep, I forgot to mention that in my first post. Only the most important thing.
Big hp + auto trans - trans cooler = dead transmission.
:icon_bigg
