Well...got my ATI damper in today.  Didn't really have the time right now, but my previous timing belt jumped a tooth so I installed a Greddy timing belt and put the ATI damper on while I had everything apart.
Couple notes on the install: In the first pic you will see the differences in the crank bolts. The ATI requires a smaller diameter flange than stock...I used a metal lathe to turn it down to the proper diameter. The hole for the damper is 1.810"...I turned the bolt down to 1.804" to give it a little clearance. It fit perfect!
The 2nd pic shows the ATI installed without the A/C pulley. Getting everything off was no problem, but I had to remove the radiator to get and impact gun on the bolt. I used a strap wrench to hold the old damper in place...it came right off.
The ATI damper is a very tight spec to the crank shaft...the instructions suggested heating the damper in boiling water, which I did. I applied anti-seize to the shaft and inside the ATI and got it started straight on the shaft. Used a rubber mallet to tap it into place...this thing was a tight fit!
The ATI fit perfect...no rubbing at all on the lower timing cover. The 3rd pic shows the A/C pulley bolted on. The 12 point bolts are torqued to 30 ft/lbs per ATI spec.
There is one thing that surprised me about the ATI...there was no timing index mark! I got a stock damper, lined the crank key grooves up with a piece of rectangular metal stock (it was exactly the width of the crank key), and marked the ATI with a triangular file. I set the timing at zero with a stock damper 1st, then installed the ATI...the marks matched exactly to the zero index on the timing cover.
I have it almost done...have to hook the radiator hoses up and check the CPS for proper alignment. Tomorrow it will run! :evil2:
