Assembly lube?
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
should i put it on BOTH sides of the bearing? Like on the main surface of the block, and then on the main cap surface? or does it only need to be on the bearing surface for start up? i just thought about it today.
Let me know.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
thank you!
IJ your like my go to guy!!!!
(i was just going to PM you but i thought everybody should know)
edit: Do you know the torque spec for the eagle rod bolts? eagle is already closed today... =[
Rennat;1019376 said:
thank you!
Nope sorry never used a set but I'm sure someone here has the documentation that comes with them ;)
