ARP Main Stud/Bolts Question
jboyle83
76
Madison,AL
That appears to be the 3rd cap from the front of the block.... Is that right? And what is it that won't clear studs on this cap?
yup if the oil pump will not bolt up then the bolts are in the wrong spot..
IJ did you make a custom crank scraper? im assuming you did. And only on the one side?
sk6471
Quietly Lurking
May 28, 2005
91
Texas
That's a nice crank scraper, Ian. How much did you have to trim it to make it work?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
A crank scrapper is used to get oil back to the sump faster, and also give more horse power because it is not continuing to keep the oil on rotating parts? That is what I always understood it to be.
