i know this is on her but i have just spent the last 15 mins searching with no results. i did a mhg and arp headstuds. i torqed them to 73 ftlbs but after tinking i thought i saw that with a mhg you torq them to 90 . is 73 ok or should i go 90/
blackie87t;1715653 said:90 is too high i torqued mine down to 83. most people suggest anywhere between 78-85 ft lbs.
blackie87t;1715715 said:well if you torque them to 90 lbs it could pintch the gasket causing it to not seat properly on the head/block.. just my .02$
hvyman;1715720 said:No its fine. 90lbs dry would be over torquing. 90lbs with the correct moly and the torque sheet that says 90lb will not hurt anything.
Buddys arp studs were 90lbs and his car has been running just fine for the past year/25k.
If you use motor oil the torque needs to be like 130lbs.
It all depends on what lube you use.
jetjock;1716849 said:No way that info would be on the ARP website. It's just not possible...
http://arp-bolts.com/pages/technical_instructions.php
IJ.;1717874 said:LMAO it's not Rocket Surgery....
