ARP Head bolt kit...
suprflyusmc1
51
Ramona
Datsrboi said:
WHERE!!!!!
some dude on craigslist found them in the garage of his cousin, who was a wholesaler of engine parts at one time. He didn't know if it was a complete kit or not. That's why I asked if 14 was the right number.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Kai said:
Aaah i always used 1/2" drive instead....3/8" just seems a little flimsy in my gargantuan hands :)
Not sure with bolts, but with the studs, the 1/2" drive socket, doesn't clear the cams, even the 3/8" is a squeeze on some of the nuts
Depending on the head casting, a lot of times a 1/2" deep well socket will not fit down the hole to engage the bolts...the wall thickness of the socket is too much. You have to use a 3/8" socket with a 3/8" to 1/2" adapter for the torque wrench.
Frank Rizzo
478
Fixing your girl's car
Yep, thats why I said 3/8" drive because it "BARELY" fits past the casting of the lifter bores. 1/2" drive will not cut it. Use adapter as stated. Use a DIGITAL torque wrench they go down to the .1 of a foot pound, very accurate if the wrench has been calibrated correctly and was not abused since the calibration.
And whoever chopped my quote up and said 14mm you are wrong. I just retorqued last weekend, I know its 1/2" not 14mm. Yes its hard to believe ARP used standard size head and metric threads, but I think they know what they are doing.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
when i did my head job i had to go out and buy an s&k (i think thats the name) thin walled socket to torque down the studs. i have lots of sockets and couldnt find one that worked.
Frank Rizzo
478
Nope. A 12 point bolt requires a 12 pt socket. The reason there is a difference between a 6 pt 1/2" socket and a 12 pt 1/2" is because there is more material removed on the 12pt socket. That is why a 6 pt is too big. And thats the same reason you should not use a 12pt on a 6pt bolt, less material to grip the bolt head, can easily be rounded off.
ARP head bolts require a 12pt 1/2" socket.
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
sweet thanks for telling me that.. good to know.. heading to the store to pick up a deep and normal 12pt...
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Are you sure about them being 1/2"?
Doesn't sound right to me...
Arp Headstuds, are 12 pt 14mm, I;m 100% sure
And I doubt the bolts are suddenly imperical instead of metric, but I haven't installed any bolts
