Are the sensors the same?
xXSupramanXx
Drifter
Mar 12, 2008
149
Dayton
I tried to search but found no results. I was wondering if the cold start switches on the coolant housing were the same between the GTE and the GE? All help is appreciated. Thanks!
bioskyline
1,236
powell river bc
there is plug in difference yes. with the pigtail its not a problem. ive found that the cold start switch seems to be the same on almost any toyota from the 80's and early 90's. it seems to be a generic densu part but im not 100% on that, as i dont know if the temp for them to stop is different. all i know is with the pigtail my supra ran a cold start switch from a 4ag.
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
Really need to have a good look at the EPC. Clearest difference is the whole ignition assembly. With the NA having a distributor and Turbo having coil packs and cam sensor.
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
The plug designs are the same, but the setup is different is what I was trying to get at. I generalized all the plugs in the car. I'll leave a sticky on the monitor reminding me NOT to view forums right after waking up :p
