Archive: MAFT Pro Questions
SupraStardom
181
Council Bluffs, IA
Here's some links to start us off!!!
drjonez's MAFT Pro FAQ:
http://www.mkiiitech.com/forums/viewtopic.php?t=641
drjonez's MAFT Pro archive (manuals, SW updates, etc.):
http://www.4cefed.com/maftpro/
How many Maft Pro in MKIII
http://www.supramania.com/forums/sho...highlight=maft
Setting up a Maft Pro in AFC mode
Maft Pro setttings and tuning
A newbies guide to setting up Maft pro with Tuner Pro Rt
http://www.mgnta.com/Documents/MAFTProSetup/Setup/
Maft Pro manual
http://www.4cefed.com/maftpro/maftpromanual_v1_0.pdf
Maft Pro Tuning thread
Maft Pro Install with wiring diagrams for Pre and Post 89 & 89+ HAC Mod
MAFT-Pro VE Table
http://www.supramania.com/forums/showthread.php?t=38513
writeup: MAFT Pro install for 7M-GE
http://www.supramania.com/forums/showthread.php?t=35302
MAFT Pro - N/A install - Translator Mode BEWARE- good bit of bad info in this thread
http://www.supramania.com/forums/showthread.php?t=31806
MAFT running..Now just needs tuning
http://www.supramania.com/forums/showthread.php?t=34451
Gain Adjustment Worksheets - SAFR, SAFC I, II & NEO, MAFT Pro & GenII ◊
http://www.supramania.com/forums/showthread.php?t=27784
Maft pro question
http://www.supramania.com/forums/showthread.php?t=33467
I just carried these over from the suggestion box
partially edited by drjonez
StefanLarsson
Viking
Jun 26, 2006
47
Sweden
If your MAFT pro LCD backlight comes on and nothing else happens and the unit seems dead, check your system voltage...
Your car's battery might be discharged, the MAFT Pro requires at least 10V.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
Hey guys let's get this section started!
I figured if we all put in on things we found helped while installing,
I'll start,
I found that the check engine light came on for codes 24 and 34 i believe, an air temp and hac sensor?
Well, I found that the maft pro was not powering up in time for the tccs to do its system check with it wired to power on using the b+ or B on the ecu, I switched the power supply to the cigerette lighter power source (i removed my cig lighter and installed a boost gauge), and have it powering on when the ignition switch turns to the acc position, I also have the wide band doing the same thing to cut down time for it to come online.
The next thing I found refers more to ANY wiring you do, but for fuel managment it is a MUST in my eyes now, I will not install another with out doing this! SOLDER!
I have used crimp conections, scotch clips, snap connections, you name it! Each time I pulled my motor I pulled my harness though the firewall, and after doing this several times it has created loose connections (you say your not pulling your motor?), well these connections can be improperly installed I.E. Bad connection, or they can loosen up on there own after awhile.
The best way to install the conections is to seperate the insulation on the wire enough to wrap the maft pro wire around it. Heat using the iron from the under side, and apply solder from the top of the wire, do not touch their on to add the solder, you want the solder to soak into the hot wire, and not puddle on top of the wire.
Make sure to use the correct solder! DO NOT use plumbing solde (acid core), use resin core.
tip from friend
My preference is "silver solder" for wires... and it is available in Rosin and Acid core, as well.
partially edited by dr.j
TRACKMKIII
464
Atlanta,GA
My Na-T set up is almost complete and I have a Maf-t pro on the way. I am wondering if I will see any gains after installation of the Maft-pro and dyno time with a stock setup or should I just wait until I have extra mods. What kind of gains should I expect?
drjonez
the motor city
www.4cefed.com
you will certainly see some gains using any tuning device on a stock setup. the gains come from both leaning it out a bit and the timing advance that comes from backing down the AFM signal.
gains vary from car to car....especially in cars as old as ours. look for 5-20 rwhp.
sweetlikechutny
235
Ontario
+1...I work with electronics on a regular bases. I've designed circuits and autonomous robots and stereo systems and while building them, I trust no other method then soldering and heat shrink. Please don't do it any other way.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
i recently upgraded to v4.8. after upgrading, i did a reset and put in my base settings. and so far everything has been going smoothly except for a few things.
1) i have my vf signal hooked up to maftpro via aux1. since i installed the pro, ive been experiencing a wierd issue. when i first start the car, the aux1 gets no reading. even after i warm it up, nothing, 0.00V. my afr are a bit high around 15-16 at idle and the ecu doesnt compensate very well during cruising. if i shut the car off after its warmed up, and start it again, everything is fine and i get a vf reading around 2.3-2.4V. anyone else having this problem.
2) about 2 days ago my vf signal started reading a little higher than usual (after i restart the car when it warms up). it used to stay around 2.3-2.4. all of a sudden its around 3.2 at idle, and goes up to 4.43 once i start driving. and it stays pegged 4.43 even after i stop driving. now my afr at idle is around 13.6 at idle. i havent changed any fuel pressure or settings except boost control. cant seem to figure out what happened to change this.
3) does anyone know where to get a quick start guide for v4.8. i know the settings are similar to v4.4 but there are a few other features that im not familiar with.
4)and finally, in tunerpro, i dont know how to create a new bin file. or where to get a bin file for v4.8.
any help would be great. ive been searching everywhere for some answers but have come up with nothing. i am trying to get these kinks ironed out before the etown meet this saturday.
thanks a lot
-pete
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Still some broken links:
"Maft Pro Install with wiring diagrams for Pre and Post 89 & 89+ HAC Mod
http://www.supramania.com/forums/sho...highlight=maft"
And I need to find the HAC mod... ugh.
Josemk3
MA
hi im new here CAN SOME ONE PLEASE HELP ME WITH THIS TRANSLATOR PRO PLEASE . I have conected all the wires speed density is my goal i cant
get it to runn please help.
pattywaggon
10
Bucks PA
I hooked up my maft pro and am trying to run on speed density
i have the IAT sensor and gm 3bar sensor hooked up
everything is fine, they are all getting signals and such that seem correct but i start the car and it will run for a split second and then die
i have all the setting in the maft pro as a guy in a thread i read
like as a basic setup.
the car ran and drove before, with the maft pro around the block but randomly stopped working
i run it on maf with another ecu just to drive it and then hook up the maft pro and try to diagnose it but havent gotten anywhere
im running the newest version of softwar 5something
Thanks
