Anyway to check motor internals aside from teardown while engines out?
gregzbutt
Toyota Love
Nov 4, 2005
10
Middletown, PA
I recently bought a used turbo engine that supposedly has ~60k on it. Its a rebuilt jasper engine (has little numbered tag on it), with a metal head gasket. I plan on swapping this into my na supra over the summer. I'll be replacing all the gaskets and cleaning it up, but I was wondering if there's anyway to test it to make sure its in good shape aside from tearing it apart? I'd like to avoid taking it apart if at all possible. Anyone have experience with jasper 7m's? Thank you.
Greg
Doward
4,245
Alachua, FL
There's no real way of knowing an engine's condition, without tearing it down.
Sure a compression test and leakdown test will tell you the condition of the sealing of the motor, but no test I am aware of (with the engine out) will tell you the condition of the bearings/oil pump, nor how clean the oil galleys are.
blackgamer16
Supra Driver
Apr 27, 2005
243
Sooner Country
A leakdown test would be a little better if somehow you do have a problem, since it will pinpoint the fault easier by going even further than a compression test would. Also its pretty easy to use, and the instructions will aide you out if you do run into a problem.
gregzbutt
Toyota Love
Nov 4, 2005
10
Middletown, PA
Sure, but don't these tests require the engine to be running? There maybe nothing I can do without installing it besides just tearing it down.
Edit: My bad I just realized you can do a leakdown test without it running. Thanks a bunch!
