Anyone using a MSD DIS4
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Like the title says, I am wondering if anyone has successfully used a DIS4, if you were able to change the rev limit, and if the 2 step worked. I would also like to know if there was a more powerfull spark.
Thanks in advance.
Not that I noticed!
Had an injector die on the dyno awhile back and it burnt a hole through a piston and the blowby pumped 2 qt's of Oil into the IC/intake and it drove the 50 Km's home no probs.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
IJ, the rest of the ignition stock, with just the DIS4?
Still wondering if the 2-step works with the stock ECU.
^ That's how I did mine
You can use 1xDis4 and 1x Dis2 to get the 6 channels but if you're firing them using the stock Ignitor 1x Dis4 in Waste fire mode makes more sense as the MSD hardware is HUGE and it's hard to find room for 2 boxes.
mabru
part-time
Apr 5, 2007
27
Okinawa JP
I'm thinking about going this route soon, I'm assuming you need to use two of the adapters to make the DIS-4 work with the JZ?
