Anyone here run a 12 Row Oil Cooler? And Mounting Locations besides the radiator.
JDMMA70
2,550
Houston
Im sitting here looking at an oil cooler that can mount in the factory location without too much trouble has anyone here mounted one of these B&M Coolers in the factory location with success?
http://www.summitracing.com/parts/bmm-70265/overview/
or
http://www.summitracing.com/parts/bmm-70273/overview/
The smaller one is a 12 row and has a 7,500 BTU rating is that sufficient enough being that it will get plenty of air via the front air dam?
Any advice and opinions welcome. I was going to mount it on the rad like i did my Trans cooler but Looking at it I do not believe the -10 hose will be able to squeeze around it.
Thanks for your time.
I will be using a 19 row earls cooler to mount between the rad and ic with space inbetween.
Just used a piece of metal to go between the ic mounts to mount it.
