Any requests for intake options
935motorsports
San Diego, CA
Other then what is already out there, what would you like to see in a intake pipe kit for NA?
We already make perfect fit intake kits, but the labor is expensive. I'm trying to figure out a cheaper way of making the intakes. These are the things that I would like to see on a cheaper intake kit:
- 100% bolt on (no ghetto rigging)
- High Quality Couplers
- Power steering idle port on the bottom where it belongs (oem location)
- Fits with strut bar
- Aluminum construction
- Cold air option
Our current kit is nearly $200 for stainless steel. But I want to provide something under $100 for the budget folks.
Shoot some ideas.
Do you have a 4" intake pipe with an apexi filter? Just a thought, and if you do......I want it.
935motorsports
San Diego, CA
I was talking about an NA intake pipe (this is the NA section).
We can do a 4" intake pipe for a single, but the APEXi filter is 80mm max, so it is going to look a little small on the end.
There is K&N and AEM for 4" filter options.
We should probably move to PM and quit clogging up the NA section.
aznwaterboy
Swap never finished
Feb 5, 2006
139
Bay Area, California
i'm sure a lot of NA people would love to see CAI systems for low budget, i'd probably buy one depending on what kind of filter is used. i just hate looking at the stock airbox everytime i open my hood
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Rob, can you get me a 70mm adapter for an Apexi filter? Like they include in the universal kit. I'm no longer running a GE AFM so I need a round neck for a hose. If it's more than half the price of the universal kit (all that I've found so far have been) I might as well pick up the whole kit and have a spare filter.
MKIIINA
Destroyer of Turbos
Plano, TX
would be a great idea i think for the NA guys. a filter alone (fipk) is expensive and if you were to make one that looks nice for a good price (the 100 or less) its great
Setheroo
^_^ got horespower?
Oct 16, 2006
285
Tennessee
www.revogate.com
- Cold air option
Now if you make something with all of the above - I will gladly buy one even with a sticker price of $100 - Gosh for an intake that isn't all ghetto rigged - I would probably go even a little higher than $100
I have seen several people fit kits from different vehicles onto their N/A's - but they have no flash, and I can't say that they added a lot of dash.
If the cold air option can be done properly, then having the intake would be a lot more worthwhile.
I will be on the lookout for this concept intake to be purchaseable.
935motorsports
San Diego, CA
Here is the beginning. I didn't like the usual civic pipe that people use, because the nipple is in the wrong place. I think this one is from a prelude. So you can see that it is a little more clean. I will add the nipple under the intake in the OEM location under the intake pipe, so you don't see it.
I will also include the proper sized couplers in black. This is just a test fit to get some idea. Last, I will add the cold air extension, to make a complete and easy kit.
CRE
Oct 24, 2005
3,485
Denver, CO
I've wondered about the location of that nipple ever since I got my setup running... on mine it's in the same spot as it was on my stock intake piping. I guess it's because I'm using a CAI kit.
C
cnewingham
Guest
Here is the one that 935Motorsports did for my old NA a few years ago.
935motorsports
San Diego, CA
I picked up some better couplers, so I'm ready to provide 3 intake pipe kits without cold air. They are going to be $75 for the first three. This is the piping, couplers, and clamps only. This includes 2 multi layer black couplers, 4 t bolt clamps, and the intake pipe.
The front part of the intake (adapter, filter, and cold air option) is still under construction.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
any word on a filter, coupler, clamps and cold air, without a filter/air adapter?
or would it be a complete set?
I already have an HKS SMP, so all i'd need is the CAI extension, and the pipe, and mounting hardware and couplers..
935motorsports
San Diego, CA
I have 2 prototypes done:
Here I have placed the hole for the power steering vac hose, so that the oem fitting can be used.
I just have to pick up some T bolt clamps, and they will be ready for sale. The pipe, couplers, T bolt clamps, complete is $99.
The full kit with HKS adapter and generic filter is $139. The cold air extension is not ready yet.
