any help on mpro
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
ive been searching and trying different things,ive posted on piggyback discussion but not reply, so sorry if this thread upsets anyone..i believe my settings are way off,and nobody around town has messed with mpro..heres my configuration sorry no tuner pro cant connect to vista still argggg!!!!
config-ver 5.03
vehicle, 0
cylinder, 6
disp, 3.0
air flow, speed density
map, 3 bar
load srce, use map
baro mode, @ sealevel
fout, supra mk3
vout1, map 3bar gm
vout2, map 3bar gm
afr source, aem gauge
fin mode, supra mk3
aux1, +v to trig aux
flow error mode, sd/tuned
system-
mainscale, -.5
vout1 max, 2.560
vout2 max, 4.000
afterstart 4.0
lo load pt, 32.5
mi load pt, 100.1
hi load pt, 143
fout max, 0
tm base, +.5
tm correct, 1.20
af tr delay, 0.0
fe smooth, 30
use ve table 1
spark base, 13
pt tracking-
idle tps, .200
idle rpm, 800
idle afr, 13.5
cruise tps, .000
cruise rpm, 2560
cruise load, 91.0
cruise a/f, 14.5
lean load, 84.5
lean delay, 10.0
lean a/f, 16.0
gain, 15.0
enable delay, 95
etps rpm, 4800
etps load, 166.4
tune resp-
tps enrich, 1.15
tps decay, .60
tb size, 7
tps map max, 104.0
map enrich, .10
bst enrich, .10
map tps min, .800
map rpm min, 2560
maf lim tps, .000
maf lim, .0
maf krpm, .0
lim min rpm, 0
lim time, .0
spark wot/spark aux @ rpm-
2000, 13.0
2500, 13.0
3000, 13.0
3500, 13.0
4000, 13.0
4500, 13.0
5000, 13.0
5500, 13.0
6000, 13.0
6500, 13.0
7000, 13.0
7500, 13.0
8000, 13.0
low,mid,hi load @rpm -
400, 0
800, 0
1200, 0
1600, 0
2200, 0
2800, 0
3400, 0
4000, 0
4600, 0
5200, 0
5800, 0
6400, 0
7000, 0
7600, 0
air temp-
-40, 0%
13f, 0%
41f, 0%
62f, 0%
82f, 0%
103f, 0%
129f, 0%
173f, 0%
212f, 0%
@aux trig-
400, 0%
800, 0%
1200, 0%
1600, 0%
2200, 0%
2800, 0%
3400, 0%
4000, 0%
4600, 0%
5200, 0%
5800, 0%
6400, 0%
7000, 0%
7600, 0%
boost(dont have the mpro bc,have the greddy pro spec b II)
tps spool, 2.5
rpm spool, 2400
tps start, 3.7
psi start, 5.0
dc% start, 10.0
psi set, 10.0
psi aux, 10.0
gain, 4.0
dc% start aux, 10.00
max rpm, 0
afr tracking-
min tps, 4.9
min rpm- 3200
min load, 166.6
lean lim%, 11.5
rich lim%, 10.0
gain, 4.0
afr
2000 - 8000rpm, 11.5
aux%, 0
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Cripes... dude, there are several things wrong with this post.
First up, read the link in my signature.
Learn to use punctuation, capitalization, and use a spell check, for crying out loud. When you're asking for our help, it's the least you can do to show respect.
On the subject of asking for help... exactly what help are you looking for? You don't ask any questions, you don't list any symptoms or problems. From this post I can't tell if you're trying to get it to start, stop, or steer.
boosted2085
I was spoolin :(
Mar 1, 2009
218
houston,tx
sorry man..on idle in full sd mode bobbing idle with decent response,in sd hybrid good idle bad response.. ive changed tps enrichment but nothing..it runs rich at idle..when cruising it seems to want to die at low rpm..with partial throttle it does ok i guess,but wot it fuel cuts hard. it was hitting 10.8psi now 9.2psi at fuel cut..what my main problem is my configuration correct, i put them to the best of my knowledge cuz apparently all these threads everyones not running higher than version 4.6 so as far as searching i get no luck
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
Have you even attempted to change your lo mid and high load rpms? You have 0s across the board there.....If you searched and couldn't find anything, check out this site for exclusive maft-pro help-----fullthrottletech.com I have some base maps on my friends lap top that you can try....Whenever I get some time i will try and send those over your way if you want them that is......
-val
