Any 1j guys with shaftmaster shafts?
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
I will be getting a 1 piece aluminum driveshaft from shaftmasters.
My question is are there any 1j guys running this shaft, and if so did they just use the 7m/154 shaft or did they have it legnthened (sp) to make up for the shallower 1j bellhousing?
Spoke with Robert at shaftmasters and he didn't think anyone with a 1j had done the 1 piece aluminum shaft but I thought I would ask.
Wayne
rob21a48422
1JZ+Holset=Go Fast!!!
Sep 7, 2007
117
Port Huron, Michigan
I thought if you were using the R154 for your swap you could use the original Turbo driveshaft meaning they're the same?? If this isn't correct could somebody please chime in as I'm going to be doing the same thing as the OP soon.
zoppii
Pro Lurker
May 21, 2007
98
Palm Harbor
I have the aluminum driveshaft from shaftmasters in my 1jz r154 setup and it works fine with the stock length intended for the 7M. That's how I ordered it to replace my steel (local made) 1 piece shaft which was for my 7M back in the day and it fit fine too.
