Anti lag system vs 2 step launch control
hex.amilli
14
plus.google.com
Hey guys,
I have been searching this topic and its very opinionated not info on both, what are the differences if any could you guys shed some light on this if you guys are familiar with em anything helps
Thanks
90 BMW E30
90 SUPRA MK3
www.TurboBuilds.com
DREAM.BUILD.DRIVE
SideWinderGX
733
Syracuse, New York, United States
You use a 2 step for staging, and anti lag to launch the car. Only rally cars use anti lag for keeping spool up for between shifts.
A 2 step keeps the rpms constant irrelevant of all other things (not interested in building boost). Anti lag keeps the rpms constant but also builds boost to aid with spool.
There are anti lag and 2 step modules, and ECUs that have these limiters already in place if you'd like to set them up.
hex.amilli
14
plus.google.com
Good thanks, the rally anti lag is what I'm interested in from what I have been reading there is also 2 different setups a rally and a drag setup. Rally being a bit more complicated but I can't find extensive info as to a parts list and install and setup info. Any info you can offer is great thanks guys
90 BMW E30
90 SUPRA MK3
www.TurboBuilds.com
DREAM.BUILD.DRIVE
DeMoN2318
572
Arizona
Not entirely true...Rally cars do use it...but they are not the ONLY ones that use it. Several guys around town here in AZ have rolling anti-lag setups that they use for roll racing...
SideWinderGX
733
Rolling anti lag is used before you start accelerating to keep the boost up (it also keeps you at exactly the speed you're going whenever you depress the switch to enable it, which is very helpful), it does not automatically enable itself in between shifts after you go WOT.
hex: I don't think I've seen any threads, here or on SF, which detail how to enable antilag between shifts. To be honest there's so few people that would use it you're going to have a hard time finding solid info on it.
DeMoN2318
572
Arizona
^^ right, you can usually set a RPM trigger that enables it and then it is activated with a switch...
atleast thats how ProEFI works...
hex.amilli
14
plus.google.com
I haven't been able to locate anything either, this is going to be harder then I thought.
90 BMW E30
90 SUPRA MK3
www.TurboBuilds.com
DREAM.BUILD.DRIVE
