Another new mkIII owner!
decepticonmk3
15
Lebanon, Ohio
Hey! I just traded my perfectly running zx3 focus for a 88 turbo mkIII that i just found out has a bhg! lol all the guys in my shop say it was a stupid move but i've always wanted supra so i don't think it was a bad trade. Anyways great site! already learned a ton!
barkz
363
Afghanistan
now you must buy this shirt and join the BHG club. i still havent met the standards for the club lol
decepticonmk3
15
Lebanon, Ohio
Yeah I loved my focus. I spent 6 years turining into a auto cross beast, but I really wanted an MK3. I'm looking around for a block and head for a 7mgte, to complely rebuild. A salvage yard here has a core motor for $250 so i might jump on that. Thinkin 350 hp is a good number to shoot for.
barkz
363
Afghanistan
ill say it before everyone else does. JZ swap will be easier/more reliable to get to the 350hp, and if you want to go up from there it will be alot easier than with a 7m
mjsn1
284
Qatif
The work that you will put in the 7m will be the work of swapping more then two or more 1jzs.
just go jz as fast as you can
Supra0089
367
New Hampshire
To give you a feeler for what building a 7m costs...
I've spent about 14k on a motor/head/new parts/ and supporting mods and am probably sitting on about 340whp w/o tuning. Another 1k in parts I should have 400+ w/ tuning.
To get the 7m to a point where it was ready for more power...cost about 2k for a fresh motor, 2k in JDM/OEM parts to get the car as mechanically new as possible (you'll be surprised how fast hoses/gaskets/wiring adds up), 2k for headgasket+work+machine, and I guess I'll count 2k for tranny supports stuff (I have an auto)....then after that...probably 5-8k in supporting mods to turn boost up...and the rest was aesthetics and upgrade parts.
For 350whp, 7m might actually be cheaper to build for you, but for more than that...you might want consider other options. I stuck with the 7m cause I wanted the challenge.
I don't know what it costs for a 1jz swap, but I would imagine a 1jz...if you do the work yourself...will be slightly cheaper if you plan on more than 350whp...but the jz series costs are somewhat foreign to me.
Will you have to buy as many oem/jdm parts as I did to make your motor capable of supporting 350? I don't know. I just like the feeling that my car is 99% mechanically new whenever I go under WOT...what it comes down it is...what's your power goal and budget? And are you married to the 7m or JZ series? THe one thing to keep in mind is...once you start feeling 290whp...then 340whp....YOU ARE GOING TO WANT MORE! I first started out wanting only 300whp...then it was 340.....now it's 400....supraddiction is a disease...so keep that in mind!
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
on the 7M, just change the rod bearings, use a good metal headgasket, torque down ARP head studs to atleast 75lbs, BPU the SOB and you can hit around 300hp, no problem..
end of story..
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
Lol at this thread. Always an argument about 7M v JZ. Who cares? It's his car, let him do the research and decide for himself. Besides, everyone knows the MKIII was an Autobot.
