This past weekend I tried starting my car for the first time on the maftpro/speed density setup. It sputtered a little, after that, it would just crank and crank... After thinking for a while, I remembered that I didn't adjust the mainscale to compensate for the 550s I have in it...So I pulled the #6 plug out and it had a strong smell of gas. So since then I changed my oil, and replaced the spark plugs. Before I try to do this again, Can you guys look over my settings and let me know if anything completely wrong jumps out at you. remember, I haven't started doing any tuning yet, right now I just want the car to start. Timing monitor is not yet set up.
thanks everyone!
TunerPro Bin Data Export
Source File: tpro4600.bin
Source Definition: TPro4600.xdf
Constants
Vehicle Select 00
Number of Cylinders 6
Displacement 3.00 Liter
Airflow Source 0x00 Select
Manifold pressure source 00
Density Comp Source 0x00
Barometer Comp Mode 01
Frequency Out Mode 0x04
V Out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 2 Select
Freq In Mode 0
Aux 1 mode 00
Main Scale -10.00
Volts Out 1 Setpoint 2.51
Volts Out 2 Setpoint 4.00
Afterstart enrichment 0.00
Tune Load Point, Low 36.40
Tune Load Point, Mid 100.10
Tune Load Point, High 143.00
Freq Out Max 0
Timing Monitor, Base Adjust 0.00
Timing Monitor, Correction 1.27
AFR Tracking, Enable delay 0.00 Seconds
FE Smoothing 30
Boost control TPS Spool 2.50
Boost control RPM Spool 2400 RPM
Boost control TPS Start 3.70 Volts
Boost control PSI Start 5.00 PSI
Boost control DC% Start 10.00 Percent
Boost control PSI Set 10.00 PSI
Boost control PSI Aux 10.00 PSI
Boost Control Gain 4.00
Boost Control DC% Start Aux 10.00 Percent
Boost Control Max RPM 0.00
AFR Min TPS 4.90
AFR Min RPM 3200
AFR Min MAP 166.50
AFR correction lean limit 10.00
AFR correction rich limit 17.00
AFR correction gain 4.00
AFR Aux % 0.00
TPS Enrichment 0.50
TPS Decay 0.80
Throttle Body Size 7
TPS MAP Max 104.06
MAP Enrichment 0.40
Boost Enrichment 0.40
MAP TPS Min 0.40 Volts
MAP RPM Min 640.00
MAF Limit TPS Threshold 0.00 Volts
MAF Limit 0.00
MAF Limit / KRPM 0.00 Grams/Sec
Flags
Tables
AFR Tracking
AFR AFR
2000 3000 4000 5000 6000 7000 8000
A/F Ratio 11.50 11.50 11.50 11.50 11.50 11.50 11.50
VE table
MAP(Kpa) RPM
00 400 800 1200 1600 2200 2800 3400 4000 4600 5200 5800 6400 7000 7600
320 78.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
300 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
280 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
260 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
240 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
220 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
200 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
180 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
160 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
140 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
120 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 88.0
100 77.0 77.0 77.0 80.5 83.5 87.0 90.0 93.5 93.5 92.5 91.5 90.0 89.0 88.0 87.0
80 70.0 70.0 70.0 75.0 80.0 82.0 83.5 88.5 82.5 81.5 80.5 79.0 78.0 77.0 77.0
60 66.0 62.0 62.0 67.0 71.0 75.0 78.5 82.5 71.5 70.5 69.5 68.0 67.0 66.0 66.0
40 62.0 56.0 56.0 58.0 63.0 64.0 68.0 69.5 60.5 59.5 58.5 57.0 56.0 56.0 56.0
20 57.0 48.0 48.0 51.0 53.0 55.5 58.5 59.5 51.5 49.5 48.5 47.5 47.5 47.5 47.5
00 0.0 0.0 0.0 0.0 48.0 49.5 51.5 53.5 46.0 44.0 43.0 42.0 42.0 42.0 42.0
AF User Tune Hi
RPM
Percent 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
AF UserTune Mid
RPM
AF User Tune Lo
RPM
Aux Triggered tune
Percent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Air Temp Correction
degrees
-40.00 13.00 41.00 62.00 82.00 103.00 129.00 173.00 315.00
Pecent 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
Spark WOT
RPM
2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000
Degrees 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00
Spark Aux
RPM
thanks everyone!
Constants
Vehicle Select 00
AFR Source 2 Select
Freq In Mode 0
Aux 1 mode 00
Main Scale -10.00
Freq Out Max 0
FE Smoothing 30
AFR Min TPS 4.90
AFR Min RPM 3200
AFR Min MAP 166.50
AFR Aux % 0.00
TPS Enrichment 0.50
TPS Decay 0.80
TPS MAP Max 104.06
MAP Enrichment 0.40
MAP RPM Min 640.00
MAF Limit 0.00
Flags
Tables
AFR Tracking
AFR AFR
VE table
MAP(Kpa) RPM
AF User Tune Hi
RPM
AF UserTune Mid
RPM
AF User Tune Lo
RPM
Aux Triggered tune
Air Temp Correction
degrees
Spark WOT
RPM
Spark Aux
RPM
