Another HID group buy?
Ckanderson
2,644
The beach
i dont know if bulbs count but ill throw your name in the mix anyways!
guys this is a great way to make money! sell these to your friends for 150 bucks!
Come on! Chris wants HID's in the lincoln!
Ckanderson
2,644
The beach
annoyingrob said:
what's happening with the last GB? I lost the thread link, and wanted to know when I'm getting my lights :)
since your canada i have to do customs.
everyone else has shipped. im doing the canada guys stuff tomarow.
Blame Canada!
Satan
Tampa
CK is the deal... I'm in for almost whatever he sells ;-)
I'd like to have HIDs in both the MKIII and MKIV.
MKIII - Want better lighting (like newer cars) and to work like stock without blinding people (high beam and low beam)... Recommendation? Write-up? Housings purchased separately?
MKIV - Using Sylvania 9006s now.. HID options?
Satan: get the Hella E-codes from here: http://www.rallylights.com/hella/200mm.asp
They get a bixenon H4 kit from Chris in a 4300K (that's stock for all HID systems), or you can get 6000K's for more bluish white...
Fogs will need an H3 kit in 3000K if you want yellow. Foglight rewire is required with HID's, and you'll need to use a resister to get the high bea indicator to work.
On the MKIV, you'd use HID's for low beam, and a good halogen for the high's (rapid on/off isn't good for the HID's, and HID's have to warm up)
Not sure on the plug style for the MKIV though...
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
mkiv is def 9006 for lows and H3 for fogs i think.
for the MKIV lows, youre gonna want a D2S with a casper sheild/adaptor. this will let you use a GENUINE D2S bulb and not some rebased unit built made in a sweat shop.
in addition to HID"s needing to warm up, they have to cool down too. if you cycle them on and off rapidly, the metal halide inside condenses on the capsule itself and sullies the light color and output. eventuall, your 5000k will look like a old, worn out Flourescent light with a white/pink color.
Satan
Tampa
On that same page, they have these DOT-approved ones... Are they the same or does the E-code do something different (only ~$2 difference)?
HL72207 200mm Vision Plus Rectangular DOT Headlamp
