another head gasket question
mazzer
438
st.louis,mo
i have the head off my 7m-gte and im doing the metal replacement and arp studs.. what im lookin for is the head bolt torque specs. ive heard many different numbers such as 52lb/ft , some in the 70's and some in the 90's....
souprat
fairfax VA
52ft/lbs is what toyota trorqued them to, and thats what causes the hg's to blow, dont torque it to 52. i have mine at 85 on a mhg.
4
425hpmk3
Guest
the torque specs come with the arp studs if you are using the molly lube you torque to 80 pounds if you are using 10 w 30 you torque to 120
