another BHG
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
lol i have a few questions never done a compression test before
how many times do i crank the engine over so forth so on?
How many times do i test each cyl. to get a proper test done
Cam cover need to be put on? Ground wires?
Bare head will be fine
Open throttle 100% Crank 2>3 times for each cylinder and have a backup battery and jumper leads ready in case it gets low.
Watch the gauge it'll peak and then drop back a touch this is enough any more cranking will just flatten the battery!
bobiseverywhere
bobb'n for money
Montreal
Me too
I was thinking when i go to crank it over drain the oil but dont refill it. I was only thinking that since nothing else is hooked up and well oil will come out for the turbo connection or fill it back up with good oil and then crank it and to bad about the oil coming out.
bobiseverywhere
bobb'n for money
Montreal
I have a bad feeling too. but there is still hope left. My engine is evil but somewhere deep in there. there still is some good left. LOL all that aside
we will see. If i have to get another engine i am going to have to pay someone to put it in cause i am just not able to do a job that big.
bobiseverywhere
bobb'n for money
Montreal
Ok here are the numbers Guys
Sorry it took an extra day my landlord got pissed at me doing work on my car in the garage
I did not put any oil in any of the cylinders to get these numbers
PSI
#1 - 158
#2 - 160
#3 - 80
:3d_frown:
#4 - 145
#5 - 170
#6 - 165
I might just put it back together and run this engine into the ground. It would be cheaper for me to buy another engine and stuff it in, then to repair the one i have now
