Am i in the right direction to hit 450 HP
juan jz
197
Anaheim
Hey everyone my goal is to hit 450HP and I need suggestions of what I might need to get there. Let me know what I might need in my combo so I can achieve my goal. I know a single turbo will put me up there but I want to see how far my twins will go. I'm running a 1JZ, with MK4 water pump/fan clutch, Koyo aluminum radiator, DM front mount intercooler, DM down pipe, 3'exhaust no Cat, HKS TI carbon fiber exhaust, This week I purchased a apexi SAFC II black, Aeromotive fuel pressure regulator kit with hard lines from DM, and AEM boost gauge/type controller.
My next purchase is going to be a set of 550, but doing research to find a set that I will not have to sauder in, (looking for direct fit I don't want to burst into flames),
juan jz
197
Anaheim
Yup I forgot about that but yeah I have a walbro fuel pump installed already, how much more can I boost up safely
umran9
15
UK
how much boost pressure you running? has the downpipe raised boost pressure? looking to do similar mods to mine...
juan jz
197
Anaheim
Its still stock boost, my autometer reads at 11 pounds. Hopefully I have time this weekend to install the AEM boost gauge type controller for more acuracy. Then I'm going to go up to 12 or 14 I just have to do more research and find out if that's safe
becauseican
Vancouver
www.bicperformance.com
Stock twins wont get you 450...you might hit 350, thats the highest I have seen on stock twins. A 60 trim t3/t4 or 61 mm turbo will get you there with good spool. I made 440 whp on my 7m with a 60trim/ P trim turbo at 16 psi. I am currently making 423hp with a DBB T61 at 18 psi on pump gas.
apexi287
401
Knoxville, TN
I made 370hp on my stock twins at 16psi, and at 18psi and 440cc injectors with a slight tune im around 400hp although no dyno chart of the 400. I agree though stock twins won't get 450 a good 61mm would do the trick.
juan jz
197
Anaheim
So your saying I'm going to need a Fuel cut defensor soo the ecu works with the set up, and a speed cut defensor to be able to dyno. I think the speed cut is been tapered with I don't think it works, because at around 105 all that happens is the check engine light comes on. I would be happy with 400, thank u guys
juan jz
197
Anaheim
I'm on the search for the FCD then... , I know there's also the option of cams do u guys have any suggetions, I don't want anything too agressive, I was looking at the cheap way, having a set of 2J cams machined for the 1J.
