Alternator relocation bracket doesn't fit??
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
Anyone else run into this problem? I bought a LIPP relocation bracket but it does not line up with the bolt holes on the alternator. It's off by 1/4 or more (too small) and I don't think there's enough material to cut the holes so it could be used.
Just curious if anyone else has found this, I didn't see any posts on it. Also, mine was sent with a 65" belt, the correct belt would be 46-47"
Thanks,
Brian
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
Thanks,
Brian
Hey Brian,
Didin't I suggest you buy the Beech Performance relocation bracket? Man, that's a bummer the bracket doesnt fit your alternator. I've never heard of the LIPP bracket not working with a stock alternator. They didn't send you the right bracket kit? That's all I can think happened. Van
SWD Fredester 3
674
baltimore maryland
Is this the one you're asking about or is it a drop down bracket?
This one I have fit fine.
mytmk3
643
christchurch
I have this one and my alternator didn't fit but mines a jdm digidash model so maybe had a bigger one had to get a smaller alternator to use it
8,897
Van;1664239 said:
Hey Brian,
Didin't I suggest you buy the Beech Performance relocation bracket?.... I've never heard of the LIPP bracket not working with a stock alternator.
Why suggest a different one? With the complaints I have read regarding (SS)customoer service? Because quality of product being poor from them has to be rare. The things I have bought that they(LIPP) made have been first rate quality.
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
That's the one I'm trying to use Fredester, the bolt holes are ~3/16 to close together. Thought it might be enought material to bore out and get the lower piece to line up but it would be awfully thin to make that work. Maybe they had a bad casting run?
I'm going to try something else, should've thought to check it up front when the belt was incorrect too.
---------- Post added at 09:34 PM ---------- Previous post was at 09:31 PM ----------
Van;1664239 said:
Hey Brian,
I should've listened :) Don't worry, I'm taking your advice on some of the other stuff I'll be using.
SWD Fredester 3
674
baltimore maryland
toyolla86;1664812 said:
which belt do you use with that bracket. how much do these cost. i like that thing .maybe ill just make one.
Can't remember the belt size. It would be different when using the ATI damper instead of the OEM damper for the same set up.
Supra Sport sells the the cast alum. for $85, Wes Beech sells the billet alum. for $90.
Captain
80
NM
I used the beech bracket and it seemed like it would work with an OEM alternator. However, it didnt quite fit the MR2 alternator.
I think the key point here is that there is a little adjustability in the OEM mounting setup to adjust for different size alternators.
letitride4life
10
kansas
I Need help too i just got mine in the mail and it does not fit my alternator i have a 1988 toyota supra plus the belt seems way to long. let me know what you end up doing to get it to work.i mean it's off just barely but not close enough to get it to work
---------- Post added at 07:14 PM ---------- Previous post was at 07:12 PM ----------
I can also post pics tomorrow of how it is off
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
Thanks,
Brian
Brian,
I went out Sunday, looked at the ALT, it's a Bosch ALT. It fits the Beech Performance bracket well and the stock Supra plug and wire go right in to the socket and pole.
As for the right sized belt: I too used a length of string to get a measurement. Van
letitride4life
10
kansas
My alternator is a Denso it says toyota on it so i am assuming it's the factory one since i have never replaced it. unfortunately i haven't received any word from supra sport, which has been a problem i have had with them before and it's starting to make me mad with there customer support.
funky_monkey58
Closing in on 200+MPH
Apr 3, 2006
1,307
St.cloud MN
The problem is the 87-88 supras got one size of alternator from the factory and the 89+ got a different size.
This is not really noticable with the factory brackets as the upper and lower are independent upon each other, so you are going to need the newer style alternator.
It is what it is and there is no guarantee that any supra for sure has one vs the other because of the stock interchangeability.
I used to do tech support for SS, and now the only time that anyone is in the office to answer calls is on tuesdays.
(I am in no way affiliated with SupraSport, outside of being friends with the people that own and run it.)
letitride4life
10
kansas
Well thanks alot for the info i guess i will try and find another alternator to at least try and mock up before purchasing. it is a little bit of a bummer that it wasn't posted on the product page to at least notify a customer that this could pose a problem. but like i said thank you for the response
