born2drv said:hey figgie just curious, what did the conversion cost you? or what would it cost someone at today's price to convert?
what kind of hp are you generating? does it detract anything from performance? ie. could you build a 500hp E85 supra?
CPT Furious said:At least you have hair, IJ! BTW...if you hooked up a grill in the back of your Supra, you could be the most popular tail-gater at matches (games for the US folk!). It's not just a car, it's a grill!![]()
figgie said:something I never do is state how much I paid for something or a project. What I can tell you is that it is not by any means cheap for just running e-85 normally and if high HP is the goal , most of the typical cheap MKIII owners would have cadiac for what it cost me.
ethanol and fuel mixture containing 85 percent ethanol and the rest fuel. Some newer american cars have them as a factory optiomn and its catchign on. e-85 is avail at gas stations in the US and soon to be up north. You dont always have to run e-85 though, its an option of that or pure fuel. And i want to be the 2nd person to have this system as soon as i see e-85 popping up around here.johnathan1 said:ok, what is E-85?
born2drv said:I can understand that, but do you think you would be able to give just a range what it would cost doing it from the "economy" way vs. "high performance" setup?
I just want to get an idea of what I would be looking to spend to do this, both from the low end entry stuff all the way to the best components around, you don't have to say what it cost you specifically.
And I am by no means cheapFor the past 8 months I've averaged about $1500/mo on my supra. This month and next will be no different! :evil2:
SMP142 said:i am going to be in the process of upgrading my fuel system within the near future. at the same time i will be installing a maf-t pro. would it be worth the extra cost to go ahead and make my fuel system e85 capable? i am already planning on pump, lines, fpr, injectors, and fuel rail. from readin it seem like those are pretty much all you gotta change in order to run e85. i am trying to get all this figured out before i go spend money on stuff then turn around and want to run alchy. what do you all think?
SMP142 said:now if you were running a maf-t pro with all the mods needed for the e85 setup. would you be able to switch back and forth between the two fuels by using different maps? b/c if i ever planned to go on a long road trip i know i would have to use reg gas since most places still dont carry the product. is this possible or am i way in left field?
